Hey up - this is not advice - just what I have done…
I have had the car for 4 years now - I think.
I took mine to anglesey track day earlier this year knowing that at 53k and using bags of oil something was going to go!
I had just fitted the remote stat but still suffered HGF (classic elastomer fail) on the PM session (pity as it was a cracking day upto then
Fortunately I had planned on a rebuild anyway so it wasnt a shock. Its had plenty of spirited use on the road and a couple of track outings.
Dave Andrews has just rebuilt it and I have yet to put it back in. I’m fannying about minting up various bits before putting it back together.
Basically the motor was next door to FUBARed. The mains were picking up, bores(liners) worn etc… As suspected it was more that ready for a reight good fettlin’.
So pistons, bearings, liners, head port, new oil ladder, bolts, piper cams (already had verniers and an Emerald fitted), sump baffles, release bearing, clutch and the whole lot balanced etc…
Oil filter mount was cracked and since discovered the electric water pump (kicks in to recirc coolant engine off) was not working neither was the IACV.
I managed to get a mount from a great bloke who is also an Exiger or it would av been �120+
Aircon compressor pipe unions were corroded and new ones swaged on (not tested it yet so may be more problems up front).
Basically its going to cost me best part of �4k to get it running again but I’m happy its all been done as it will be like new.
So if its done 60k with no history of a refresh - get ready!
Good luck and although its not running yet Dave seems to have done a great job and was good to deal with - he knows his onions that chap
Simon
