Hi
I took the Exige for a run today and coming “enthusiastically” round the last roundabout before home, it coughed twice and then died. I restarted the engine, but as soon as I let the clutch out it died again. Tried various things like waiting a couple of mins with ignition off etc, engine would run and rev fine until I let the clutch out. Eventually after 15 mins or so I managed to get the car moving and then everything seemed fine until I tried to reverse back up the drive into the garage, when I encountered exactly the same problem.
Anyone got any ideas what I should check first?
Thanks
Alex
Anyone know whether its possible to dismantle these plugs so that I can reattach the wires and if not what the best solution would be.
Failing that anyone know a good mobile auto sparky near to Basingstoke?
Alex
Alex
Hi Alex,
I think it’ll be difficult to dismantle and make a good connection again. I had the same problem with a Air Temp sensor plug and managed to get all the correct fittings and wire from these guys, give them a ring very helpful and delivered within 48hrs.
Easy job, if you’ve got a set of crimps and a soldering iron.
Thanks Graham, only thing that concerns me is where this connector is sited would mean its going to get a fair bit of abuse - water, stones etc so would need to be pretty tough. But may have to use one of theirs and try and protect it somehow.
Alex
