Help with a cold draft up myTrouser leg!!!!
I have a problem with two drafts, one comes up the column housing and one from by my left foot.
Before I have the front clam off to investigate, has anyone come across this before with a simple fix.
When I get to work I cany walk at the moment due to frost bite in the foot. I have even put extra socks on! :sick:
In the footwells (both driver & passenger) you’ll see numerouus round vent holes. Cover them with an old number plate (cut to size), attached by double sided sticky stuff, or velcro.
Or remove some of the rear interior and you will get a nice hot draft from the engine bay to compensate. :slight_smile:
'Tis the joy of S1 ownership. If you had an S2, you’d only need to adjust the air con :smiley:
Picture by FlyingDutchman, pinched from thread about ariels:
Thanks. this will be a lot quicker than a Font Clam off!
Mine with “blanks” as suggested:
PMSL, and S1 owners call S2 owners :smiley:
