Knocking noise when turning right …and a bit during straight line running.
Knock is exagerated by the camera mount .
It is speed related so not Engine and car was checked over by the Edwards who found no obvious probs with wheel bearings etc.
It does not appear to be brakes
SO any suggestions…
Hmm it almost seems like a rubbing noise rather than a knock… sorta like a rub rub rub rub, almost like tyre treads catching something.
I suppose you’ve checked all of your tyres and sidewalls?. You’ve also checked that the trigger wheels on the rear outer CVs haven’t moved and are rubbing on something?
Any idea whether it’s coming from front or rear? I’d imagine a noise that loud would cause significant steering vibration if on the front?
I’m experiencing a speed-related knock which is cured when I touch the brakes.Suspecting pad knck back or someting. Only happens after I’ve been on road for a few miles.
Thanks guys for the suggestions…
Most of the obvious ones have been eliminated…but a CV joint could be a suspect even though there is no obvious visible prob.Will also look again at the wheel arch liners but it sounds a bit too metallic for that.
Brake pads no… as it still does it if I apply brakes in a corner (Not totally advisable at full chat going through Paddock!)
Hi Simon…Just tried that but no conclusions due to all the other noises going on.
Its booked in to Martin for a complete joint rebuild/replacement so lets hope that helps…cheers.
All sorted by the wonderful Martin and Steve …NS rear wheel bearing knackered…Ns tripod and cv joints very worn, os CV worn…
Cant wait to get it out on track for a meaningful test…
Thanks guys for a superb job…
