Thanks for your replies guys, is this something I need to get replaced before the trackday or can it wait til after? I’m afraid, it’s going to be difficult (read impossible) to get an appointement at my local Lotus garage before the weekend.
But if it is a serious problem, aka something that could break…then I better cancel the track day. Better be safe than sorry right ?
again thanks for your help! appreciate it!
No you should be fine. A good check to do before all of your track days is to jack up each corner and check for any free play or movement, both up and down, side to side and back and forth, by simply grabbing the jacked up wheel and giving it a wobble. If you do have any movement, then you should get it looked at, if not, then crack straight on!!
