Hi All
I’ve got a 2010 Exige and the both doors will lock with the key fob, however when you push to open on the key fob the passenger door unlocks but the drivers side doesn’t….
I have had the drivers door actuator out and 12 volts across it and it opens and closes the actuator ok depending on the polarity.
Have put a meter across the supply to the drivers door actuator and when closing the reading is around 12 volts, however when opening it’s in the 1 to 3 volt range or less!
Lotus Cars have suggested it is probably a faulty Central Door Locking Module but this requires removal of the dash to access…
Any other ideas and anyone got a manual including how to remove the dash or diagram I can get?
Thanks in advance
