Desperate for some instructions on how to remove the front clamshell.Thank you
Have you got access to a fax machine? If so, I will send you the relevant pages out of the workshop manual. Rob Gibbons
Ive done it now but thanks anyway where did you get the manual from.The fault turned out to be a badly crimped radiator. Bloody lotus plastic and ally rad. the two should never mix.
Ive done it now turned out to be a badly crimped rad.Do you know where i can get one thats a bit better made.And where did you get your service manual from???
You can get the service manual from your local dealer…or search the net for the pdf version !! [image]http://www.exiges.com/ubb/NonCGI/images/icons/wink.gif[/image]
I got the manual from B&C, but I had to order it. �60 (!) I seem to remember.Rob Gibbons
quote:Originally posted by Phil Davies @ home:You can get the service manual from your local dealer…or search the net for the pdf version !! [image]http://www.exiges.com/ubb/NonCGI/images/icons/wink.gif[/image]Any ideas where i might find this nudge nudge
