I am mounting my Dave Andrews motor and have run into a problem. The new motor comes with Jenvey TBs that are about 1 inch shorter than the stock TBs. I also received a Bernard Scouse Airbox kit. When I attempt to mount the aibox, it hits the coolent pipe (engine return) that mounts under the airbox. How have people solved that problem??
According to the Lotus Parts book, the coolent pipe, engine return, is the same for the Elise/Elise II/Exige/340r.
Roy
fit spacers between the t/bs & the aluminium backing plate?
I thought that the trumpets in the airbox were tuned (by their precise length) so as to maximise torque, so if you add spacers you will change the lengths and may end up losing instead of gaining power…
