Anyone here good with remotely operated garage doors
I have managed to lose the remote & can’t access the garage. Is there a way around this without damaging the doors or lock??
HELP
Its an up & over door btw
HELP
Have you thought about buying a laser jammer, as they apparently operate garage doors?
Seriously though, mate, good luck. Phone call to the manufacturers?
Have you tried “Open Sesame”
Thought that was a Danish style sarnie from MaccyD
Blimey this soon got off topic
Update - I only have one remote (which may be in the garage), the door does not have a separate lock, there is only the up & over door to get access inside, & the power can’t be isolated externally.
Even the door manufacturer info is in the garage
HELP!!!
If the mains box is not in the garage, kill the power and then when you turn it back on it may open?
Would a TV remote perform the required job?
Or am I talking out of my A*se?
Problem solved
I found the remote
Thank god for that, even the local locksmiths advice was ‘you’re fooked’
Thanks for all the helpfull hints.
Cheers,
Tim
[quote]Problem solved
I found the remote
Eaten by your pooch?
You can normally get a barrel and the key fitted to release the door, it might be worth getting one while you can still get in there…
You’re right, I’ll look into that
Pesky - nope. Ask it to his face on the 29th
[quote]
Pesky - nope. Ask it to his face on the 29th [/quote]
Will I need a stepladder?
[quote][quote]
Will I need a stepladder? [/quote]
Nah, He’ll find your face anyway…& give it some big licks
