Help - Front bonnet stuck
Hi
We have an S1 Exige and the battery is dead, but we can’t get the bonnet open. We have tried pulling whilst pulling the latch, we have also removed the wheel liner and are trying to get it undone there, but the air con pipes are in the way.
How can we get this open?!
My other half needs it for work in the morning!!
Thanks in advance for any help, we’ll carry on pulling and prodding for now!!
Oh and we suspect the front of the bonnet has come loose which is why we can’t release the rear latch!
:crazy:
Lisa
Get someone to pull the release on the handle, whist someone else wiggles the front hatch left, right, forwards and backwards. If the pin is out of alignment, this should allow it to open.
If the cable is really stiff to pull, press the bonnet down then try it.
Try to put a cable around the pin and push in all directions while trying to press and pull on the bonnet.
Been there, done that! :clap:
Good luck!! :sunglasses:
Nice to hear from you after all this time. Best of luck with the prob.
