Help for the guys with problems on the Emerald
Hi All
I receive many emails of people with problems in the Emerald in the engines when have a complete injection map and running with the car out of the normal place on the map was made, normally mountain or beach.
Well here a data obtained in real time with the latest technology.
For the perfectly work of the Ecu you need a Baro sensor and wideband.
As a Baro sensor you can use a MAP sensor Bosch ref 0261230004 and as wideband the LC1 work perfectly.
To convert the MAP sensor in Baro sensor in this case is easy, should not connect to the inlet manifold and there that leave let it take the pressure of the atmosphere directly.
This model of MAP Bosch is used in many quantity of race car as a Baro sensor.
This is the correct data for the corrections and help Emerald:
AFR Target values engines without CAT:
Baro values:
Wideband values closed loop:
Feedback values:
I hope this helps many of you and if some of you need more data, please tell me.
All the best
Vicente
