Heavy-Duty FilterMAG Oil Filter Magnetic Clip On
Does anyone have any experience of THESE ?
I suppose it might work, but how many of the moving parts are ferrous ??
Mike good point - hopefully an engine techie will comment…
rings?
liners
bearings
shells?
crank
camshaft
most of it i’d think ?? no ?..
thing i’d wonder about is will fitting this to your oil filter interfere with the flow thru’ it?? i guess it would drag all the ferrous bits to the outside of the filter and clag this up faster??
Mike - if there was enough loose metal to clog the filter, I think the engine would already be scrap!!!
yeh yeh… i figured that, but if this thing actually does anything then that was what i thoguhut about… see… not very clear but
I think it is supposed to keep the particles on the very outside of the filter and thus away from the flow through the filter - it also is supposed to retain particles that are so small that they would pass straight throught the filter and so never clog it
