I don’t need a heater, as I only run my car on track in the summer.
While I could remove the matrix and connect the supply/return pipes together, I’d just assume blank it out in the engine compartment.
The tricky bit is the return pipe - it is a Y-like hard pipe merging the radiator return and heater return right at the thermostat - a complicated little piece of hardware.
340R’s did not have heaters. What did 340R’s and the AutobyTel cars do? The 340R Service Notes section doesn’t say much.
I saw the part number in the MSport parts manual - radiator return pipe part #A111E6229S, does anyone know if that is a radiator return pipe, sans heater return port?
