Heater - Hot air flow
Is it only me, or does the heater on its highest setting blow hot from the screen and centre vents, and not so hot from the footwell vents ? Why is that ?
Don’t forget to put yer sox on, when wearing these
[image]http://www.global-b2b-network.com/direct/dbimage/50272982/Sandals.jpg[/image]
do they have a heater on an S1? or would that be against the racing purity thingy
I believe they do, but mine’s fooked, making winter driving somewhat chilly
Thought about getting a sheepskin coat - know any good sources in the valleys?
Try John Motson!
Only fitted as part of the auxillary engine coolant temperature stabilisation system. Less weight than additional fans
I wish you poor S1 people would go back to your own side of the forum, I have a serious question here !
Thought about getting a sheepskin coat - know any good sources in the valleys? [/quote]
From what I’ve read on here Pesky you may prefer the “older” style coat, in which case you might want to try a Mr. Bernie Winters!!
This place has never been the same since they let S2s in
You should remember that every post we make bumps your topic back to the top - therefore you are more likely to get a sensible reply…well…
It has always seemed to me even on the fastest setting the foot vents only blow at the rate of an asmatic mouse…
