…put S2 cup wheels on their S1 exige? & would there be any advantage in even doing it?
marc.
marc.
They don’t fit.
Different PCD and offset.
They don’t fit.
they will with some spacers and correct wheel nuts
Are you sure?
Standard S2 wheels will definitely with some kind of hub adapter, I think Junks said something about it in an old thread…
Here�s the thread, hope it helps a bit.
http://www.exiges.com/ubbthreads/showflat.php?Cat=&Number=81887&page=&view=&sb=5&o=&fpart=all&vc=1
They don’t fit.
but then you open up the issue regarding wheel bearings…
They don’t fit.
There is a bit more to it than spacers and wheel nuts as someone has described. You need to use a hub adaptor, and IMHO they are a really crap idea and open up a whole world of issues regarding run-out, tightening, bearing offset loads etc.
