New cars can have a few teething probs (mine did) but considering the hard life it leads I am impressed (if I treated any of my previous cars like eg track work etc they would be in bits by now).
The Exige and 111R share a lot of DNA so most 111R will have the same probs.
I’ve still got an ongoing brake issue,they keep binding when hot,always just after you have stopped in traffic,only way to release them is to either pull up the brake pedal or dab the brakes.
Only problems I’ve had are an intermittent stalling problem fixed with a new ECU download, and a leaking aircon pipe. Both sorted now. Really pleased with my car
thanks for posts. every forum i look at (seloc, pistoheads, scottishelises) all of them suggest air con is a must. seems purchasing a model without air con may actually be one less thing to worry about
Stalling problem and noisy roof seals sorted under warranty was it up until my Walshy day last Thursday. Now I�ve got a noise when changing gear, but only when coming off the throttle high on the second cam and going back on the gas. Occasional single mechanical clinking noise but doesn�t sound internal to the engine. (My best attempt at explaining it so far, but it still sounds stupid) Maybe the exhaust or something is moving on full chat, or something springing back into place, throttle cable maybe? Haven�t had a chance to look at it yet but I�m sure the dealer will sort it if I can�t.
Although your never gonna get hyperthermia from the air con it does stop you getting the sweaty arse/back syndrome on a hot day. Or is that just me and my hygiene problem�.
Couldn�t be happier with it. Ticks all the boxes that I want ticked. Although I am keeping an eye on the supercharger options for when my warranty runs out.
No mechanicals, just a water leak in through the roof at the start, Lotus didn’t fit the rubber seal where the roof joins the rear clam (took a while for Glasgow Lotus to spot it though). Cars been great, girlfriend drives it to work every day says it makes work worthwhile, sure does!!!
