Nathan I used Luke from Hanger111 had to remove the roof to (fit the harness bar and) remove the seats other than that it was quite straight forward and all in the instructions. Kept the seatbelts for day to day which I’d highly recommend!
Oh and some of the seat bolts can be a little fiddly to get to
really considered buying Jules s1, hondering it and getting it fully resprayed. But the time it was going to take and a few other factors put me off. So a quick s2 was the o my option. How is yours coming along, u picked a colour yet?
Ps, am I the only one that thinks it is stupid how you get a new car, pay the preimum for the sport pack then have to take your new car to bits to fit the harnesses, I am sure a few years ago when the performance pack was around this was the case!!!
Hi dan, might just do that depending on the challenge! Is it deffinatly a roof off job?
Getting a ice White exige s, 240 performance pack. Sport pack and air con, getting it Friday.
Thanks
I went for that spec as well but in Chrome Orange! (just over a month ago)
I managed to fit the harnesses without taking the roof off, but in hindsight it was a pain, lined the tub with cardboard to save scratching everything with the seat base frame, then just tilt the seat to each side to get at the fixings. Took way longer than expected!!
Wouldn’t your supplying dealer fit them as part of the deal (if you supply the harnesses)?? Or what about at the 1000 mile service
They might but would proba charge me on the 1500 service for the pleasure. I can’t get my supplying dealer to do it as the harnesses are in the post to me and the car is coming from Kent, very complext. I will asses how difficult it is a then if I am unhappy I will take to JPS if I am stuck!
Nath, I fitted Schroth in mine. Passenger and Driver. Definitly no need to take the roof off! Seats out though. Not difficult. 2 Hour job max. and thats with (lots of) biscuit brakes.
I have ordered the Profi FE 4pt ASM ones degined for lotus. These are the slightly more expensive ones for some reason, push button fit they said at MSAR.
Do is it just a seat out job then, does the hareness bar have to be removed at all or do the just loop around it like a noose? Thanks.
