Im looking at buying a harness because am going to be doing a fair bit of track daying… just looking through techwiki and i cant really tell where the fixings are that u bolt the waist to and how easy is it to fit the rap around harness to the bar? is there any checks that need to be done before hand?
to retain the 3-point seatbelt buy the longer bolt fixing kit from MSAR
http://www.msar-safety.com/s111-harness-hardware-lotus-elise-exige-340r-p-83.html
Fitting is fiddly…do a search I ran a thread a 18 months ago.
cheers damon
The waist ones fit to the same bolt in the side of the seat as the one that holds the 3 point belt to. Presumably there is provision in the seats for a bolt in both sides as the seats aren’t handed for driver/pax.
If you don’t want to cut holes in your plastic panel behind the seats to thread a bar through there are bars that bolt to the oe seat belt mounts but they can reduce how much the seat goes back and may interfere with the speakers.
Do your seats have holes in for the shoulder harness routing?
Ash I bought my harness bar (bolted to the roll bar), Luke harness and pads x2 (well comfy) from Hanger 111. Roof off, seats out and rear plastic panel out and cut. Easy peasy. If you need one cut (keep yours for resale), you can have mine as it’s no longer in anyway.
ive already got the harness bar in and i have the exige seats with the holes out of the seat… just finding out on where to bolt the side harnesses too i think the luke harness is the all round favourite at the moment… other question i just had is helmet… which one do u all prefer full helmet or open face? im unsure what to go for… am looking for a fia or MSA approved as all the tracks are going towards them for trackdays now… any help will be great… thanks
I have a full face Arai GP-5S but in retrospect should maybe have gone for an open face…gets a little too warm inside our cars on track. I usually end up with the window open!
ok thats good… omp have some good ones on ebay that i was looking at and msar-safety have some harnesses
http://www.msar-safety.com/profi-ii-fe-lotus-4pt-asm-right-hand-p-111.html
contemplationg on gettin one of them
Pesky and I have this…
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=OMPSC722L
Meets the emerging regs for trackdays and GVFM IMO
I’d go for a full face as you never know when your going to be offered a pax ride in something interesting. If it gets hot I turn the aircon on as it’s supposed to cut out under hard acceleration so doesn’t seem to slow the car down much.
Hi Ash,
Perhaps, the following tutorial can help you a little bit: Tuto Harnesses
cheers fred… any chance on gettin all that translated into english mate? i notic u got 2 tabs one in french and one in english but they are both the same… much appreciated tho…
Thanks to all that help… dont know where i would of started you all given me ideas to think about and what to buy and how to install
You can use Google Translate Ash
Give it the URL and it will translate the page.
my mistake if both are french!.. shame on me… don’t loose your time, i need to correct this, give me a few minutes as I have recently changed my notebook for a f… slow one…
[quote=fred2602]Hi Ash,
Perhaps, the following tutorial can help you a little bit: Tuto Harnesses [/quote]
Just a quick note to confirm that the url has been finally updated (end of my troubles with my laptop…).
Ash, I have also send you the file by email, I don’t know if you got it or if it has gone directly to your Junk mailbox…
hey fred yeah cheers… only just come onto my laptop myself too busy with work… great help u know your stuff keep up the good work
thanks
