Does anyone know if the Gpan fits with the Cup260 shear panel?
No It wont.
The shear panel is about 80mm to wide.
The gpan has a bigger sump area than standard and thats why it fouls.
Currently developing a shear panel that will fit with the gPan
bother, how long do you think till it will be ready?
If only Carlsberg made Sheer Panels
Ex77
We had problems with this, we ended up making an internal baffle system for the standard sump, does everything but give you the extra oil capaciy but worked fine on a couple of Cup 260’s that did a lot of track miles last year. Circa �200 I think but I’d need to check.
Worked fine …because they didn’t blow up ??? What happened to the other ones ???
Worked fine because we didn’t have oil pressure problems…
hi
i believe the sump from Eliseparts might fit with the panel ?
anyone can confirm ?
cheers
