So I buy a 260 Cup which cost 50K and so far I’ve had to change/replace/upgrade the following to allow track use
Brakes - changed fluid from new (cause the original was crap), changed pads after 4k and now need to change discs after 7k
2)Suspension - changed because the springs were too soft and the 2010 MY cars couldn’t be lowered enough for real track use
Oil - gearbox and engine changed due to being crap
Gear cables - looks like I need new ones as the standard production car ones are crap
Gearbox - looks like I’ll need to change 3rd gear before it gives up and maybe fit an oil cooler
Seat runner - original one rocked and rattled so bought a Lotus fixed seat runner that took 7 months to get and didn’t have enough holes to get an acceptable driving position
1)your discs lasted 7k? (must be driving like a girl )
2)you’ll need a better roll bar as well
3)can’t argue with that
4)mine are still fine after 24k (your just fussy )
5)if it’s not broken leave it alone
6)your obviously just an odd shape
now stop whinging and get on with driving it, 2 weeks till Spa
[quote=chrisexigegt]So I buy a 260 Cup which cost 50K and so far I’ve had to change/replace/upgrade the following to allow track use
Still think the car’s brilliant though [/quote]
So a massive thank you to Lotus from me for making cars that need to be modified-----LOL
MORE UPGRADE PARTS ANYONE???
I don’t really understand this - why can’t they be lowered, what is different about them?
The other thing is that you can’t lower the S2’s more then around 20mm without serious affecting the handling due to the wishbone angles etc…and of course smashing your headlights to pieces if you are getting on with the job whilst on track.
[quote=jonamacg83][quote=chrisexigegt]
Jonny [/quote]
You should see what you headlights are like on a fast down hill hairpin
Even with Motorsport anti roll bar and stiffer suspension.
I remember i read somewhere that if you need to lower that 125mm then the upright will also need to be changed to other version…i think i read it on eliseparts website somewhere before
Dudes when I think about all the money I spent on my car to get it where it is now I look around and there still isn’t a car that can touch it on the road for same amount…seriously stupid money for a rocket pig.
