Gearset
My new Jubu gears have turned up and they look, well like gears with Jubu on the side…
Lets hope they work, the gearbox will be with JSR this week and I hope to get the gears and LSD to them next week, no time to get it done before Easter though :frowning: unless they now have a rather large gap in their diary and I collect it on the way :wink:
Good luck matey. I’ll be keeping an eye on your progress with these as I’m sure it’s just a matter of time until my gearbox dies. I should have the same sort of figures you have (hopefully 300’ish horses) soon. I’m getting there with sourcing some bits and booking the car in for work. Got some nice lairy gold anodized intercooler pipes from RLS in the post today…they look effing gr8!
The chargecooler, 2bular larger bore manifold/exhaust and TRD airbox/filter are being fitted on Saturday at MMG…will the car drive ok without being tuned straight away? I dont think Sinclairs can fit me in for the fuel pump, pulley and remap for a month so will driving around in that state of tune.
Everything should be ok except the manifold, this will probably make the AFR go lean which is very bad :frowning:
ok…message recieved loud and clear…as little driving as possible then. Guess I’ll be Ok to actually drive it to sinclairs tho???
The main issue is full or close to full throttle when the car changes the normal map with short and long term fuel trim to a fixed map and then it will run lean :wink:
