Whilst the engine is out, thinking of getting a CR gearbox dumped in. Is there any benefit over the one already in it?
If u want i have some some parts of a quaife UCR gearkit. Then u can buy the remaining parts from quaife and fit an UCR.Very low mileage.e-mail me if interested.On my car i have the UCR and would never use the standard one (CR) anymore.Nicolas
quote:Originally posted by Nicolas:If u want i have some some parts of a quaife UCR gearkit. Then u can buy the remaining parts from quaife and fit an UCR.Very low mileage.e-mail me if interested.On my car i have the UCR and would never use the standard one (CR) anymore.NicolasI’ve read the Quaife’s are quite noisey?
of course…staight cut… [image]http://www.exiges.com/ubb/NonCGI/images/icons/smile.gif[/image]it depends on what u want, my Exige is my 2nd car.
The Lotus UCR gear set is semi-helical, and thus quieter than a straight cut set, but a little bit noisier than the standard set. You don’t really notice the extra noise on most roads, but on a motorway it’s a little bit wearing. Motorways are for poofs anyway, so it doesn’t bother me.The lower gearing really does make a big difference to driving the car, it makes the car feel much faster because you can really keep it right in the power band, and when you’re going for it, you get through the gears really quickly. With the standard box you barely use 4th and 5th, but the UCR set makes them more more useful.
quote:Originally posted by Tubbs:Whilst the engine is out, thinking of getting a CR gearbox dumped in. Is there any benefit over the one already in it? None what so ever, you already have the CR box ! [image]http://www.exiges.com/ubb/NonCGI/images/icons/wink.gif[/image]
quote:Originally posted by Phil: None what so ever, you already have the CR box ! [image]http://www.exiges.com/ubb/NonCGI/images/icons/wink.gif[/image]Would it not worry you that Lakeside didn’t know that?Obviously meant UCR - found that the Exige has CR by trawling old messages…[This message has been edited by Tubbs (edited 18 March 2003).]
If you want an UCR to get better acceleration, I’d spend that ��� on uprating your engine for better acceleration.That way your top speed doesn’t get reduced to something daft.
quote:Originally posted by Tubbs: Would it not worry you that Lakeside didn’t know that?Very much so !! [image]http://www.exiges.com/ubb/NonCGI/images/icons/blush.gif[/image]
quote:Originally posted by Phil: Very much so !! [image]http://www.exiges.com/ubb/NonCGI/images/icons/blush.gif[/image]Well, either which way, gone for the UCR upgrade. Granted, the top end wil be recuced, but I really don’t do anything much above 100 in the car cross country anyway, thus not losing much.Should be a laugh! Would of liked to have gone for a sequential, but the �’s just too much.
quote:Originally posted by Admin5:If you want an UCR to get better acceleration, I’d spend that ��� on uprating your engine for better acceleration.That way your top speed doesn’t get reduced to something daft.The UCR gear set doesn’t actually reduce the top speed of an otherwise standard Exige. It limits the car to something like 137mph, which is more than you’re likely to get out of a standard car.The real reason to choose the UCR set is to make the car FEEL faster without affecting reliability. I doubt you can make the car feel as fast by spending a couple of grand on the engine without risking it blowing up.What am I talking about? As if the engine is reliable as standard [image]http://www.exiges.com/ubb/NonCGI/images/icons/frown.gif[/image]
quote:Originally posted by Tubbs:but I really don’t do anything much above 100 in the car cross country anyway Yer not trying hard enough ! [image]http://www.exiges.com/ubb/NonCGI/images/icons/grin.gif[/image] Regularly see 140-150 in mine (cough) on the track.
quote:Originally posted by Brendan: The UCR gear set doesn’t actually reduce the top speed of an otherwise standard Exige. It limits the car to something like 137mph, which is more than you’re likely to get out of a standard car.The real reason to choose the UCR set is to make the car FEEL faster without affecting reliability. I doubt you can make the car feel as fast by spending a couple of grand on the engine without risking it blowing up.What am I talking about? As if the engine is reliable as standard [image]http://www.exiges.com/ubb/NonCGI/images/icons/frown.gif[/image]Unfortunately, my engine has been sick, to say the least, thus I was not prepared to spend a few grand on it until I know that it is not going to blow up on me (again!)Add to this, the UCR will be good for track days which is what I am hoping to do quite a few of this year (time permitting)Not to mention is should be slightly quicker as the shift should hold its revs better.
quote:Not to mention is should be slightly quicker as the shift should hold its revs better. Huh ? No makey sense [image]http://www.exiges.com/ubb/NonCGI/images/icons/smile.gif[/image]Not forgetting you lose time/speed with each gear change which could offset some of the gains with shorter gearing.[This message has been edited by Admin5 (edited 20 March 2003).]
Not to mention is should be slightly quicker as the shift should hold its revs better. Huh ? No makey sense [image]> http://www.exiges.com/ubb/NonCGI/images/icons/smile.gif> [/image]Not forgetting you lose time/speed with each gear change which could offset some of the gains with shorter gearing.[This message has been edited by Admin5 (edited 20 March 2003).]
I guessed it holds higher revs better? No? Didn’t take into account that the gearing would mean more changes I guess.
i just say: try one with UCR…Of course if u have 240+ hp and u r interested in high speeds it does not make sense…
quote:Originally posted by Nicolas:i just say: try one with UCR…Of course if u have 240+ hp and u r interested in high speeds it does not make sense…It is a UCR being fitted in the end. The parts are being ordered from Quaife, but are not the straight cut ones. Would be too noisey for road use and a semi daily driver.
