After reading a fair few things about the exige gearbox i have realised its crap. Mine is crunching a bit when i go into 3rd when cold, is there any gearbox oil that will make it last a bit longer. Also i see that hanger 111 do the juba replacment 3rd and 4th that i hear you guys take about, its about �1100 but is that for them to fit it or do they just surply a new box and you give them your old one. Any help would be great
Thanks rick
Redline MT90 gearbox oil will help a lot, I know it sounds strange but just try not to use 3rd till the box warms up a bit
I’d suggest ringing Hanger 111 to ask what the price includes as the gears are ~�700 on their own
Thanks for that ade will give them a bell see what they say.
Rick
How much oil is needed to refill a Toyota box?
Think I will order some from Opie
[quote=scoob]How much oil is needed to refill a Toyota box?
Think I will order some from Opie [/quote]
2.3 litres
[quote=Podger][quote=scoob]How much oil is needed to refill a Toyota box?
2.3 litres[/quote]
Thank you
Had another look on hanger 111 and it was �1100 just for the gears so dread to think how much it would be to get them fitted. Is there a finel drive gear that can give the exige a bit more top end speed?
Rick
There’s a Celica spec gearbox, that has a longer 6th gear. You won’t get to max revs in 6th without a big jump in power though. Saying that, you won’t with a standard gearbox either!
How bigger jump we talking?
Rick
As far as I can tell, the gearboxes are
C60 Celica 6 speed - same as Lotus, but 6th at 8k is 181 mph
C64 Lotus 6 speed box - 6th at 8k is 161mph
C63 MR2 has longer ratios throughout, no gaurantee that this fits though - 6th at 8k is 208 mph
See this http://en.wikipedia.org/wiki/Toyota_C_transmission for models, might even be correct!!
Power jump to hit the limiter on the Lotus box, not that much - Ade/Frank?? - C64 more, C63 much more!! Any mods to give you enough power to achieve the second two, are going to shorten the life of the rest of the gearbox however.
might be a jubu geared gearbox for sale soon, just need to see the white car
What sort of wedge would that be going for?
Rick
193 mph with Toyota E153. You really don’t wanna go that fast in a stock aero Exige even if you could… I know once was enough for me.
Girl!!
I don’t want to egg you on, but you know you wan’it
If I was starting afresh, with the knowledge I have now, that would be where I’d be putting my wongga
So what sort of power you running frank to get that sort of speed? And were the hell did you do it?
Rick
Do you guys at jsracing do any gearbox convertions?
Rick
Welcome aboard Rick. Best you have a read here:
http://www.exiges.com/ubbz/ubbthreads.php?ubb=showflat&Number=143567
14 pages on Gearboxes and other banter.
[quote=Mcwill]So what sort of power you running frank to get that sort of speed? And were the hell did you do it?
Rick [/quote]
680WHP and $M’s of R$D.
Ex77
