…and not all over the pit lane
Looks like an oil seal. Just got a rush to sort it for spa then Wales.
Ooooof!
Bollox.
Are you sure it didn’t come out of the Aventador in front.
Worrying …
Hope no damage was done
I know how costly things can be bud…
Bugger
Costly
So is the diff knackered ?
Any idea what caused it ?
Guesswork, but the small circling that holds the inner shaft in place may not have been following protocol.
This may have allowed the shaft to migrate outwards, spilling the oil and ripping the splines. The quaife splines look ok as best I can tell. I think they are made of proper metal and not Lotus cheese
There must be some metal bits somewhere but with most of the gearbox oil spewing out I hope that might have cleansed it.
Fingers crossed for you.
I had a l/h driveshaft snap off in the diff just after I had the quaife fitted a few years ago …thankfully a new shaft was all that was needed…
As a precaution I think it’s prudent to use a new circlip each time a shaft is removed and refitted …
I assume you will be using a new shaft?
If they are on back order and you need a useable s/h one for Anglesey let me know, Happy to loan you one!!
Circlip from the Toyota stealer,s is £2.24 plus the dreaded !
Part number T90521-27005
Agree with that although I can’t see it as a separate item on de roure
It’s not a separate item on deroure …
Main dealer only !
Well worth 3 quid imho …
I could be wrong but I think Lotus stipulate a new circlip on refitment of the shaft , probably for the very reason we’ve both discovered to our cost !
Although Paul Matty sorted mine foc .
Driveshafts were last put in by Essex Autosport and I don’t know if new clips were used.
Water under the bridge I suppose
Thanks. It’s good to see you’re still fighting for ‘Top Bloke of the Year’ award.
That’s a very kind offer. Steff has put an order in through B+C who say Lotus have 1 on the shelf. Should get it Tuesday. if it’s not what we need I’ll arrange a courier to Opp North.
