Gearbox oil capacity?
How many litres is needed for a change on the S2??
Ta
(don’t have the manual to hand!)
Transmission oil viscosity; SAE 75W/90
Specification; API GL-4 or GL-5
Quantity; 2.3 litres
THanks Neil!
hello
do you think gearbox oil of higher grade 80w140 will do the job ? maybe resist better to high temperature ?
Depends if you have a problem with the box or not, but sticking to the advised 75w 90 is safest IMO.
Going thicker may make things worse.
A good synthetic oil will improve things a good deal.
Mine was getting a bit notchy on track and Motul has solved it on other cars in the past.
