fyi Damper Weights.....
Yes I know, I’m a bit of an anorak… :blush:
Bilstein Non Adj…F:2.25kg R:2.80kg OEM
Ohlin 36mm 2 way…F:2.30kg R:2.70kg 325/425
Ohlin 46mm 2 way…F:2.90kg R:3.40kg 425/550
And my Mrs thinks I’m sad
What do your carbon fibre scales weigh? :smiley:
[quote=6970K]
What do your carbon fibre scales weigh? :smiley: [/quote]
Lol you should see my carbon fibre house!
Oh dear… how are you going to compensate for the extra 2.6kg that you’ve just added back on to your car? Disaster :smiley:
What spring rates are those with Jonny? I only ask as there’s typically quite a few more grams in a higher rate spring.
If you think you’re an anorak EVERY single component I possess is weighed to the nearest gram!
Sorted :wink:
Like your style :smiley:
Thanks for that Jonny!
No problem. Come on Shorrocks get your 1-way 46mm Ohlins up and you Nitron people…join the Anorak party!
