Hi All, especially Dave A
I am trying to identify the fuel injector fitted to my 190 K series. It has a part number 0280150749 and also has two other numbers on it - 957 and 089. The body is white and what looks like the makers symbol which is a II inside a circle ? I need to source another set, anybody got any or know where I can buy them from. Thanks
I have several new sets in stock here, they are the standard EU2 Rover K injector, ubiquitous across the range of 1600, 1800, VVC and VHPD. They are 218cc/min
Dave
Hi Dave, how much for a set, also what would be the maximum bhp I could achieve with these, is 200 OK?
Also I have a set of blue injectors from an EU3 VVC engine, part number 0280 156024 are these compatible? The target engine is a 190bhp VHPD on throttle bodies running MEMS3 ECU. Thanks Tony
I can do you a new set for �75 + P&P. The blue VVC injectors are 190cc/min, so they are 12% less capacity. The fawn injectors are good for around 220BHP, more if you up the fuel pressure.
Dave
Dave
Fawn injectors? They sound deer…
I’ll get me coat…
Careful Steven, you will awake ‘him’…
Dave
