Having owned 3 other S2 Elise’s/Exiges before this you’d have thought I’d have come across this prob before, but I haven’t. Following a bulb failure on the front o/s indicator Is there any simple explanation on how to remove the lens without breaking the indicator or stabbing a screw driver through the clam?!? I’ve tried carefully for well over 30 mins without anything happening!
I suppose wheel off, wheel arch liner out and push in the clip Dan, give that a go. Also buy some of these funny fellas…
Or alternatively once you accelerate to triple digit speeds they usually pop out on their own
Cheers fella, wheel liner off, sounds like the way to go. I’ll give that a go. Ta Dan
No problem
Can you not just push a small screw driver in the hole in front of the grill in the curvature?? 2 second job
Been trying this for the past 2 days, not getting anywhere with it. I’m gonna take the front wheel and arch liner out and try it this way instead.
