Ok, what’s the trick with getting the front clam of an S2.
Got all the bolts out at the door hinges and along the bottom of the windscreen but still solid at the front.
Does the Exige have bolts under the headlight shroud? if so how do you get the headlight lens off?
Am I missing any other bolts???
Have you seen Techwiki on Seloc mate? I think there’s a “How to” on there…
There is one bolt under each headlight that needs to be removed - the headlight needs to come out. The headlight is held in by three screws behind the wheel arch liner. Should be obvious once removed.
[quote=Mr Pesky]
What are you up to? [/quote]
[quote=Wallsy][quote=Mr Pesky]
Killing midges?
Pop out the indicators to disconnect wiring harness. Suggest removing wheel arch liners then 2 bolts at inside connect clam to lower wing at each side.
[quote=Mr Pesky]
Killing midges? [/quote]
Nah, I’d need a bigger hammer.
Thanks folks for the tips, the front clam has now replaced the coffee table in the living room!
is this the same procedure for s1 too??
