Came across this on Komo Tec looks like it would work on 240R and S
The Lotus Exige 220S �also over 250 HP
The result of the comparison test between the Lotus - Exige S �work cars �and ours �turbo-drive �concept in July expenditure �the cars - picture Sportscars �gave numerous inquiries to us after an increase in output of the Exige S of compressor engine.
The largest Handicap of the Lotus - compressor - variant is the cooling of load air.
Over an air scoop at the roof with only few square centimeters cross section and bellows in the engine compartment itself the cooling air must to the air-to-air one - intercoolers �obligations �
The load air temperatures of over 80�C, measured by us, are beneficial for the achievement nor �the health �of the engine thereby neither and force Lotus to the adjustment of the characteristic diagram of the electronic controller to �the less favourable work conditions �
The original intercooler receives therefore from us a water jacket from that the coolant over an electrical water pump to the radiator in the vehicle front is carried. - A solution, which worked in the best way with ours �turbo-drive �
The substantial sinking of the load air temperature permits now an achievement-optimized configuration controllers - of the characteristic diagram.
�Recover to �250 HP and a torque of 229 Nm with moderate 6,300 rpm are the result of this achievement cure those not only all other engine components leaves untouched, but with one �package price �from � 2,930 - also much �VALUE (HP) for money �offers.
Achievement kit Exige S (compressor) consisting of:
- Intercoolers in water/air execution (in the exchange)
- electrical water pump
- Water hoses
- Front Wasserk�hler for LLK
- optimized engine expensive equipment (in the exchange)
- Komo Tec carbon air box system
- Assembly material
- Tuningarantie
- Power measurement
- Installation
Price: � 2930
