FOR SALE:- QED 204bhp/159 Race Spec Engine + Parts
QED 204bhp/159 Race Spec K-Series Engine ( ex-B10WN K ) Dyno chart available
QED Spec (or so I’ve been told!):-
Club MotorSport Kit
This kit is intended purely for motorsport use andshould produce 205* bhp at around 8000 rpm with peak torque of up to 150* ftlb from 5000 to 6000 rpm.
The kit uses our direct to head throttle bodies, our Q425MK (inlet) and Q395MK (exhaust) profile cams, and also involves changing the engine management system. Because of the more aggressive cam profile the kit includes better valve springs and pistons with deeper valve pockets. Included as a part of the kit is porting work to be carried out on your existing cylinder head. Rods are also re-bushed to accommodate the new pistons, again on your own components.
80 mm forged omega pistons
Bushed con rod to suit above
Banded cyl liners
Heavy-duty head gasket
Large inlet & exhaust valves
Race valve springs
Steel retainers
Steel followers
Top hat shims
Q425 mechanical inlet cam
Q395 mechanical exhaust cam
Alloy vernier cam wheels
Up rated oil pump
Throttle bodies
Two injectors per cylinder
90 mm trumpets
Itg air filter
Distributor less ignition
Ultra light steel flywheel
This engine was removed from the car as it was smoking slightly. On inspection have been told it probably just requires new liners and rings. It’s complete but stripped down for any inspection. All other components look in immaculate condition and have covered low mileage. Over �10k has been spent on this engine.
I don’t know that much about tuned K series engines so any questions please ask QED etc direct.
QED Website:- http://www.qednet.demon.co.uk/
� Sensible Offers Invited - would like to sell complete but may consider splitting
Other items available:-
DTA programmable ECU (as per Emerald etc) with data logging, launch contol etc.
Lotus Close Ratio Gearbox (done about 11,000 miles) as fitted to the 111S Elise
250BHP Uprated motorsport Clutch
Starter Motor
Alternator
� Sensible offers
Email me [email protected]
Bring on Audi power!
Gearbox sold, have offers on the throttle bodies and ECU/loom etc.
If you’re interested in any of the other parts, Omega pistons/rods, cylinder head etc etc let me know as I may split it all up.
Have been offered �2.5k for the complete engine/ecu etc. If anyones interested let me know
Will
