Hope this is ok to post here, maybe of intrest if you own a S1 or S2 Exige and want to go racing
This car was built from the tub up in the winter of 2006/2007, everything that was necessary was replaced with the view to building a reliable / competitive race car. It’s continued to be maintained at this level.
It�s been a very competitive car running at the front in class B of the Elise Trophy & still is a competitive Sprint , Hillclimb, track car.
It can weigh sub 700kg and made 247bhp & 170lbpft at Emerald Feb 08 with the spec below.
Engine:
1.9 Scholar block
Tungsten inserted crank by Steve Smith from Vibration Free.
Arrow Rods
Pistal pistons
Baffled sump
DVA (Dave Andrews) ported MS1 head with 32.5 & 27.3 valves
Piper 2180 & 1444 cams
Full engine balance by Steve Smith from Vibration Free.
(engine refresh spring 08, less then 1k covered todate)
Emerald k3 ECU
Jenney throttle bodies,
Auto-Teknix race airbox and trumpets.
Laminova engine oil cooler
Auto-Teknix lightweight & uprated engine mount, uprated gearbox mount
EBD manifold & Eliseparts SCRP and 6� backbox
Quaife 6 speed syncro gearbox with Quaife LSD (full rebuild winter 2007)
Helix racing clutch and flywheel
Laminova gearbox oil cooler & pump
Spare 5 speed gearbox including clutch & fly
Racing Dynamics 3 way suspension. (rebuilt winter 07)
Custom made lightweight wishbones with nylatron bushes
Full set of standard wishbones + spares
Uniball rear toelinks
Plans Motorsport up-rated anti roll bar
290 front discs with Performance Friction 01�s + various Pagid 14�s & 42�s + Motorsport front discs
Motorsport rear discs with various Pagid 14�s & 42�s
2 full sets of 340r alloys + spare fronts & rears (including original Lotus centre caps)
2 full sets of A048�s + odd front and rears
front set of 38�s
Custom made single skin roof & rear screen
Full original soft-top and perspex rear screen
Carbon fibre rear wing & end plates
Front areo splitter
Lotus A frame & petty bar (including MSA certification)
Reverie carbon fibre drivers seat with 6 point Willians harness
Pair of original seats with 4 point Willians harness
Anomalies:
Up-rated motorsport radiator & fan
80 oc PRT remote stat
SPA gauges for oil temp / pressure. Fuel pressure & voltage
Cartek electric cut off
Lifeline fire extinguisher
Lots not listed, plus a huge amount of spares & options including most original parts.
Fully road legal
Private plate
Feel free to ask for more info on anything.
�22,500ono (possible part exchange / swap for S2 / S1 Exige)
