I have owned this car since October 2007 and spent 3 years slowly modifying and upgrading before taking the plunge in 2010 and fully race preparing the car for the 2011 Lotus Cup UK series. The Car finished 7th overall and 2nd in class, only missing out on the class win down to a driver error DNF at Silverstone. This was up against a team fully supported by Sinclair’s with Jamie Stanley as paid driver, so the car was very competitive. All race support and in season preparation was provided by JS Racing meaning the car was well sorted and looked after. With 90K driver the car was weighing it at 980 is kilo’s so also very light for an Exige
The car has been stored at JS Racing since the end of the 2011 season and was recently relocated to my garage on the south coast
Due to changes in lifestyle and priorities I am no longer intending to race this car again so am putting it up for sale.
Car Spec
Lotus Exiges S 220 delivered from factory with Sport Pack, Super Sport pack, Ltd Slip Diff, Air Con & Metallic Aubergine paint
Enhancements & modifications (in no particular order)
Nitron 2 way adjustable shocks with Eibach springs & helpers
Full Lotus FIA Rollcage. Lotus Part No AL53V0022J
Pro Alloy 55 litre fuel tank
Pro Alloy Charge cooler system
Air Con removed
2bular 4-1 header, 130mm dia Sports Cat 8” dia x24” systems with Euro Exit Tips
Sincalair remap. TDI tested at start of 2011 season 254 bhp at wheels
TRD Air Filter
Tillet T5 race seat
Luke 5 point race harness and shoulder pads (FIA approval expired 2012)
OMP steering wheel on Elise parts removable boss
Lifeline 360 plumbed in Extinguisher system (2 jets in cabin,4 in engine compartment)
Cartec Electrical Cutoff
Sector 111 G Pan baffled sump
Sector 111 Track Engine Mounts
Oil blow-by Twin Cans
Uprated Denson Fuel pump
Lotus Cup UK spec Carbon fibre adjustable rear race (mounted directly to chassis)
Large 308mm front brake disks
2 x gearboxes. LSD box removed from car (3rd gear gone)
Lightened flywheel & Helix race clutch
All wishbones fitted with rose joint kit
Factory fitted Lotus lightweight race wheels on Yoko 48’s
Engine run on Motul 300v Race oil and changed after every race weekend
Mileage 14,100 (although 99% of these have been either track days or race events !!)
Now for the not so good
Whilst the car was well maintained throughout its life and during the 2011 race season it has had no attention paid to it once the season ended and is in need of some TLC.
As part of the race prep the front and rear clams, roof and engine cover were replaced with lightweight aftermarket items and the front light clusters removed and replaced with glass fibre covers. Two driving lights were fitted behind the front grill
The interior has been stripped including the removal of window and door opening mechanisms but I still have the majority of bits for re fitting if required
It needs a new front clam and front splitter and although not damaged the lightweight roof might warrant replacement. The lightweight engine cover was replaced at some point during the race season and has not been colour matched, but then again the car will need a full respray once front clam has been replaced .
The incident at Silverstone necessitated a small welding repair to the drivers side lower wishbone mounting point which was carried out with great skill by Pro Alloy. (without knowing about this it is not noticeable on the car and has no negative effect on the cars geometry or handling)
I have tried to cover everything and be as honest as possible. Sure there are some additional bits & pieces on the car that I have missed
Have trailer so can deliver car
All enquires please respond via the forum or call me direct on 07788 497498
