Brand new , only run on the test dyno where a camshaft broke .
The engine is complete and includes Inlet manifold, throttle body, injectors, fuel rail, + all sensors on manifold, starter motor, exhaust manifold, water pump, pump idler, thermostat housing, flywheel, front top engine mount, crankshaft pulley, crankshaft sensor, cam sensor, rear vvc sensors, oil pressure switch, coolant temp sensors. Excludes gearbox .
Photos available of engine .
Full reciepts available .
�1400
