Floppy mirrors
There is noise about this on Seloc but no useful answers. I am getting my S1 ready for its trips to Donny. Whenever I go fast ( for me) the door mirrors flop inwards. I lock them in place with a couple of turns is duck tape.
Is it possible to tighten them up? I can remove the mirror from the door and get the glass out of the surround. The spring which holds the main assembly in place is tight and I fear breaking something removing it and I am not sure wht can be done once it is removed. I can buy two new mirrors, and get them sprayed but that is an expensive option…
Yeah its a bloody nightmare and as far as I know there is no was to adjust them. My original S1 mirrors were really tight, but I have had to replace a few over time and all the new ones have been a bit loose.
Try Viagra.
Might have this wrong but I know Ive had the same problem and saw the way the spring and the “arm” it pulls on are held to the mirror back by a self tapper and small washer.
The “arm” can easy come away from the washer when you use a strong spring.
I think a new (strong) spring and larger washer, stopping the arm coming away from the backshell fixed it for me …
Still up Andy!!! :wink:
It’s good here eh!!! :sunglasses:
Andy,
Arm, spring and washer are all in place. It is not that part that flops, it is the bit under the rubber belows that is loose. I have found you cn get new ones for �10. Looks like that and a trip to the spray shop.
I read a few years back that roughening the ball joint of the mirror housing works. So that’s it then, roughen your balls.
HTH,
Kurt
yeah, some coarse emery tape over the ball of the joint and it’ll tighten it up a good’un :slight_smile:
I also read the rumour about making the ball rough. Anyone managed to get on apart without breaking it? The spring is very tight.
I purchased a new mirror for £10. Chopped the mirror adjuster off and shortened the fixing pegs (just as Lotus do). I am getting sprayed but the finish of the new mirror has a slight texture, so it needs to be rubbed back and primed.
When it’s done I will be able to see people catching me on the track.
Pump a bit of expanding foam into it !
