Floor corrosion
Hi guys,
Just wondered and wanted to know if any of you have the the little bumps appearing under the black mats in the footwells.
Theres some info on Elises and from what Ive been told by a friend who works at Mattys, Lotus are still looking into it
You only have the problem if you have the black mats stuck to the floor. My Elise had them and the Exige does and Ive had the bumps on both!
I cant decide whether to rip up the black mats or leave it until Lotus decide on a cure?
Have any of you taken action yet?
Paul
Hi Robbo was chatting with an Elise owner Tues night at NYLOC bash - his Liz is particularly affected by the floor ‘corrosion’. He was in contact with Lotus on Monday and was told that ‘cure/fix’ will be out in June/July time. Understand cure will be some kind of snake oil rub if not too bad, but over/underplating if perforations are that serious We’ll wait and see…
Although my floor is o.k.(a few minor pimple size bumps) I have removed the rubber mats all the same as it is these I understand that they reckon has caused the problem…
Yep - Ignored the whole debate
Seriously until Lotus make a clear statement about the effect and “cure” I’m not taking any action - if I were an owner that doesnt read any BBS I would be non the wiser … and wouldnt have done anything ( No official letter from Lotus yet )
What length is the corrosion warranty ?
Sounds like my old mini…
In 10 years time when all our ‘k’ series are tired out we’ll all be able to push Fred Flintstone style
Andy, I agree totally, there must be a lot of Elise / Exige owners out there who dont log on and will never know until their recalled.
Its up to Lotus to sort but just dont really want any plating of holes if I can help it.
I’d be more worried if I still had the Elise, there was a bump in one of the floors about 1cm high!!!
I know something, its gonna cost Lotus a few quid
Robbo
If I were you, I’d lift the rubber matting & have a gander! As far as I know, the corrosion is a result of WMD (sorry, chemical reaction! ) between the aluminium floor & rubber mats, triggered by the ingress of water between the two. Cars with additional after market carpet mats appear to fared better than those without.
The following has been copied from Lotus’s website:
[color:“blue”] Elise Footwell Floor Corrosion
Lotus would like to reassure Elise owners that we are continuing to investigate the cosmetic corrosion of the top surface of the footwell floor panels experienced by a small proportion of cars when factory fitted with plastic floor covering. This condition may take the form of staining and/or deposits of either powder or a paste like substance in the footwell.
Our engineers have been working with the chassis manufacturer and a number of specialist institutes to identify the causes of this specific issue and provide our customers with an appropriate resolution.
We thank you for your continued patience and understanding whilst the necessary testing and validation of solutions are pursued. Lotus places a high value on the satisfaction and loyalty of its customers and it is for this reason that we wish to make sure that we have identified the possible causes and have verified that the solution we introduce is effective and inconveniences our customers as little as possible.
We would like to reassure our customers that the footwell floors are not part of the primary load bearing structure and therefore the integrity of the chassis is not compromised by this condition.
Once Lotus has completed its investigations, affected vehicles will be individually assessed and where necessary will be treated under warranty through the dealer network (subject to normal warranty terms and conditions). Until such time, owners may adopt the following routine maintenance practice:
Remove any footwell floor covering to reveal the alloy surface.
Using suitable hand and eye protection, wash the footwell floor and underside of the mat using a nylon brush and clean water (do not use soap solutions as these often have a high salt content).
Mop the floor using paper towels and allow the floor and mat to dry thoroughly before refitting the mat.
Refit the mat using a 25 mm wide strip of double sided tape only along the rear edge.
It is important to lift the mat periodically and wipe the floor and mat underside to ensure the area is kept dry.
No other action should be taken at this time in order to protect against possible interference with any future recommended treatment.
As soon as further news is available, this will be advised via the Lotus Cars website and via the dealer network.
[/color]
I was fortunate(!) enough to dimwittedly spill a litre of oil in my passenger footwell … so rather than having water under the mat, there was oil … result !
Sounds like a good idea David. That should protect the floor pretty effectively
I’d been meaning to lift my mats for months and finally got round to it this week. It was quite slimy under there and there was some surface corrosion, but nothing too bad. I’ve got carpet mats, so I’ll do without the rubber.
It’s all very well ignoring the problem as it’s up to Lotus to put it right, but I personally think it’s wiser to nip it in the bud now than to wait for Lotus to get their arse into gear. Their solution has been in progress since last May for God’s sake!
Brendan
Its just I cannot imagine an owner of say, a BMW (Z4) or Audi (TT)etc reading a web site and effecting his own temporary repair on his 30 grand car ( list ), in his own time for something that was wrong in the manufacture - he would be straight to the dealer and be demanding something was … oh dear … Mmmm … Yes… Its all clear now …
Bugger your quite right after all
Andy - your avin a larff…
Anyone who hasn’t lifted their pvc stuck down mats should do it now !! and that’s an order…
Its okay to say well Lotus should do something about it… and they should… hopefully they will actually do something, but in the end its you the owner who will have to decide… they ain’t that difficult to lift and will come off in one piece, so you can put them back down if you want. I’ve left mine off.
This type of corrosion will eat thru the floor if you leave it long enough - but if you clean it up, dry it off and let it breath thereafter it should be okay
Did somebody say Manyana …
Come on you guys give those Lotus folk a break , they’ve been focused all year on giving us that brand spanking new S2 Exige - time well spent?
Anyhow a few floor perforations might aid cabin ventilation in those hot summer months
<Andy - your avin a larff… >
more power makes it fast on the straight, less weight makes it fast everywhere - Colin Chapman ROXX
QED then - corrosion rules OK
And that spanking new yankmobile. Which incidently is now probably just going to raise the funds to repair 20,000 Elise type floors!
I’ve checked mine Rox, no corrosion here
I also put it back with velcro. Easier to clean in case I get it wet.
Do I get a star?
Im definately going to take a look when I get a free weekend!
Uldis, How easy is it to get the black mats up?
I couldn’t get mine up without damaging it. Ooooerrr missus!
I’ve trashed them both, but they’re worthless sitting there under carpets anyway.
Just pull them, they didn’t break or deform.
Now, getting the old glue out is a dog. Ended using a plastic flat thing to scrape most of it off and then used white spirit to clean the remains.
You’ll take some time, but it’s easy.
And I don’t have carpets, so had to do it well.
Do I get a star?
Uldis
[image]http://www.world-of-smilies.de/html/images/smilies/weihnachten/weihnachten09.gif[/image]
hows the house move going ??
Good, moved most of the things today.
Tomorrow we’ll work hard again and everything will be done.
But we’ll have to unpack and arrange the things for the better part of the next week.
Uldis
Good luck in your new home
Not the best weather for shifting furniture etc
