Fitting oil temp/pressure gauge
Thinking about fitting an oil temp/pressure gauge and need a bit of help. Im going to order the SPA gauge, but they did need to know what thread I would need for the oil pressure sender for the block. The car currently has a moroso baffled sump fitted. Any ideas?
Hangar 111 will be able to advise as they import the Moroso …
Thanks mate
Could you let us know what is needed for this?
Mine is going in for a service next week and I’m having the Moroso fitted and might as well have the temp sender fitted to the sump.
Are you installing another sandwich plate for the pressure sender?
Neil.
