you’re gonna stick an LSD on it cos you can’t think of a reason not to?
in general i’d say buying a car, doing one trackday in it on all weather road tyres then deciding it needs an LSD indicates you wanna spend money on something cool that you don;t need, either that or you’re some sort of driving god who extracts every last percent out of his car on the public road and has concluded that a lack of LSD is dragging his commute out for an extra few seconds
Now although I’m not intending to use the Exige for that, if I happen to loose the back end on a track day I’ll enjoy holding it all the way around in a controlled way. Now I wouldn’t spend out on an LSD just for that but if it also means I get improved traction etc then maybe I would. But depends how much hence the question at the top of this thread
Yes I suspect it may work out more than its worth spending, hoping it may just be a case of picking up a 2nd hand gearbox and fitting it?
And yes the Exige is a lot different from the RX7. But at that time my daily was an S2 Elise with an Audi engine conversion, so wasn’t a shock as I knew what to expect The Exige is actually my 4th Lotus. In an ideal world I’d have another RX7 drift car, but two toy cars is more than I can justify at the moment so if I have to chose just one its a Lotus for sure
If you are going to do the clutch flywheel etc while it is out do it, other wise it will be expensive for the gain, PS if you have the box in bits, put in the jubu (or similar gears as well)
