New injector in blue, old in green.
The old one has a plastic black sheath at the tip. It doesn’t look lke it wants to come off easily or without breaking.
1- I presume the new ones need them
2- Does the old one come off
3- should I just get new ones if they are available(didn’t see this as an option when purchased)
Thanks Guys.
If the new injector didn’t come with the black plastic tip it doesn’t use it… Just use new rubber injection cushions. Make sure you don’t pinch them when installing.
Need more info ??
Deffo not a case of swap and hope …
Remaps are available for the 220 , personally I’d ditch the 220 and fit a 260 and larger pump if 300 ish is your aim
Edit … 300 only comes with smaller pulley
Can I fit the 260 ecu first then add the injectors/pulley/fuel pump/cooling later then? I assumed it would need another remap after adding the hardware so better fitting everything first?
