As I have mentioned on my old thread, a friend of mine bought my S1 from me. He has since decided to go and race Clio Cup cars, so it is up for grabs again. Below is the original advert I wrote for it ages ago, but never got around to posting up.
Lotus S1 Exige race/track car project
The thoughts behind the car were based on doing what was necessary to make the car competitive in a series like GT Cup. We wanted the car to be able to run with GT3 type cars. It is also designed for 1 hour endurance racing, although it will be competitive in both shorter sprint races and longer endurance series.
The challenges we wanted to address were the Lotus’s lack of brakes, lack of tyre on the track and lack of tyre choice in the standard 16/17 wheel sizes. So this started with the car being designed from the ground up to take 18” wheels both front and rear. This gives the biggest choice of tyres available and an endless supply of suitable wheels in all kinds of widths, weights and costs. We based the sizes and offsets round BMW M3 sizes as motorsport and road wheels for these are obviously plentiful. Bigger wheels meant we could go with bigger brakes. Better for feel, ultimate stopping power and longevity over endurance length races
The bodywork was widened to accommodate the new wheels and allow the correct ride heights etc. The uprights and wishbone setup allow us to run the larger wheels at the correct ride height while maintain the correct wishbone angles.
The car has air jacks, fast re-fulers on both sides of the car and a 100ltr Pro Alloy baffled fuel tank, making the car ready for any kind of endurance race.
The car really has been put together as a money no object project. Everything on the car is the best that I could buy. From the loom and electrics, through the MOTEC ECU and PDM, the AP brakes and master cylinders, Ohlins suspension, AIM dash, Elise parts motorsport uprights, etc etc.
The car has been wired to carry a huge amount of monitoring sensors, including yaw control, DBW throttle and adjustable traction control. The MOTEC PDM allows a vast amount of controllability and functionality
The Engine is also a spec and money no object thing. It is based around a modified, bored Audi block, with a longer throw forged VW crank, uprated H section rods and forged 83mm pistons, with ported, port-matched head, solid lifters, uprated valves, springs and caps, the wildest cams, the best suited throttle body and inlet, to the work-of-art titanium exhaust system. This turbo and engine combination produced a lively, lag free 550bhp on another vehicle and is all brand new.
This really is the ultimate kit of parts to allow someone to put together what will be an awesome track day / race car.
I have put prices next to some of the items below to indicate what each component cost me – they are not parts which are being sold individually.
Chassis
Genuine S1 Exige Chassis with zero damage. Never been crashed, always garaged. Complete with logbook and nice private plate “EX51GER”
Reconditioned and strengthened rear sub frame
AP Air jacks on Pro Alloy brackets – brand new - £1,200
Bodywork
Widened S1 Exige front and rear clams – brand new - £1,500
Motorsport vented and unvented engine covers
Templates for full flat floor included
Widened rear diffuser – brand new
All lights included
Full width carbon rear wing – brand new - £1,000
Suspension
Ohlins 46mm 2 way adjustable dampers, freshly rebuilt – 0 miles - £3,000
Reconditioned genuine Lotus wishbones all round - £1,000
Lotus 211 Top front wishbones – brand new - £300
New bearings and ball joints throughout, rose jointed inners and lower outer rears
Eliseparts competition uprights all round – brand new - £2,000
Genuine SKF wheel bearing packs with ABS sensors – brand new - £200
Cooling
Setrab twin front oil coolers
Pro Alloy triple pass engine radiator – brand new - £300
Pro Alloy charge cooler radiator – brand new - £300
Pro Alloy extra large charge cooler system – brand new - £1,500
Brakes
Front – AP 6 pot calipers with 346mm discs, alloy bells – brand new - £2,500
Rear – AP 4 pot calipers with 330mm discs, alloy bells – brand new - £2,500
JSR bias pedal box – brand new - £800
AP racing front, rear and clutch master cylinders – brand new - £400
Electrics
MOTEC M400 ECU – brand new - £1,800
MOTEC PDM – brand new - £1,800
AIM digital dash with GPS data logging - £1,500
Professional motorsport wiring loom including MOTEC Yaw control– brand new - £3,000
Custom steering wheel including rotary traction control knob, all lights, over boost, map selection etc. etc. all controllable from the wheel - £1,000
Interior
2 x MOG carbon seats with 6 point harnesses - £1,000
Safety Devices 6 point roll cage - £2,500
Lifeline electric plumbed in fire extinguisher
Carbon dash surrounds and door cards
All new switch gear
Transmission
Freshly rebuilt 6 speed VW gearbox
Quaife ATB LSD – Brand New - £900
Lightweight flywheel to suit below clutch – brand new - £400
Twin plate clutch – brand new - £1,000
Complete driveshafts – brand new - £850
Ikeya Formula sequential shifter – brand new - £1,800
Wheels & Tyres
The car has been designed to take 18” wheels all round and has been designed to take BMW M3 size and offset wheels, which are cheap and readily available in many different designs, weights etc. Bodywork will take Front max width 9” Rear max width 11”
One set of BBS style Motorsport wheels 9” width all round – brand new - £1,000
One pair of BBS style motorsport wheels 8” width – brand new - £500
2 x 295 x 30 x 18 Yoko R888’s – brand new - £600
2 x 255 x 35 x 18 Yoko R888’s – brand new - £600
2 x Dunlop slicks – brand new - £600
Fuel system
100ltr fuel tank with Mocal fast re-fulers on both sides of the car - £2,000
Engine
Set of engine mounts
Bored block, has been chemically cleaned, including all oil/water ways, undercut bores
VW forged crank – brand new - £800
Forged H section rods – brand new - £600
Forged pistons – brand new – £600
Crank, pistons, rods, clutch and flywheel balanced individually and as a set
Port matched and casting flash removed head. Skimmed, pressure tested and new valve guides fitted - £1,000
Solid lifters with uprated springs and caps – brand new - £500
Supertech uprated valves – brand new – £400
Pro Alloy baffled sump – brand new - £200
Fabricated Tubular cast manifold – brand new - £1,500
Lightweight 3 inch twin box repackable exhaust system - £1,500
Garrett GT30-76 uprated turbo with heavy-duty bearings, main shaft and heat shielding and Owens billet wheel – brand new - £1,800
TIAL Liquid cooled remote waste gate – brand new - £400
TIAL Blow off valve – brand new - £200
VW 80mm DBW throttle body
SEM Motorsports intake manifold – brand new - £600
CAT high lift solid lifter cam shafts – brand new - £800
CAT Adjustable vernier pulley – brand new - £300
Uprated bearings throughout – brand new
All belts, gaskets etc included – brand new
The car is currently a rolling shell. 90% of the bodywork mods are done, just final fitting and paint to complete. The engine has been dry built and measured and just needs final assembly. So yes there is still work to do and money to spend, but as I have stated above it really is the ultimate kit of parts to build an epic spec car.
The price needs to be in the region of £35k
If you want any more details you can speak to me or James, who is the guy that now owns it.
Hopefully the above info will answer all of the people questions who have sent me PM’s
Sean: 07967 662294
James: 07914 852660
