Final question ref inlet temps/heatsoak
Hi Everyone
I’ve now ordered a Forge from Seriously Lotus (good deal too) and just wondered one thing after my extended drive today:
When I use the full rev range in 3rd up to the shift change light, then go for fourth gear, the car seems a lot less urgent - ie the speed being gained in 3rd is at a much greater rate than 4th.
Now I understand how gear ratios, wind resistance etc all work so this isn’t a numpy question
I wondered if the long rev pull in 3rd is causing excessive inlet temps, retarding the ignition right at the point where I select 4th and thus making it die a bit?
Is that with the Forge or without ?
without - haven’t got the forge yet
I was guessing so … Mine was the same prior to fitting …
There was a very good thread on one of the US forums explaining why the car did this , fascinating reading… I,ve since forgotton what they explained .
Not sure it matters really though as when you fit the Forge and get some air too it will hopefully be cured !
It felt like "holes "in the map to me …
:wink:
yes - very much like that.
Almost to the point where it would feel like the gear change sweetspot had gone and that everything had ‘spooled down’ - which is rubbish as it’s supercharged not turbocharged.
I can’t wait to get the forge on it - I bet it will be a revelation!
Spot on !!! it felt like a late 80’s big turbo car between gearchanges …
Had me puzzled till I read the cause of it…
Irrelevent to you soon as the new intercooler will banish it.
:wink:
Lets hope so, otherwise I’ll be hunting down the side pod air cups and extra cooling I think.
I’m so glad I’m back in a Lotus where development happens at home - the 911 Turbo I had before had just been engineered to within an inch of it’s life and was no fun to ‘fettle’ :wink:
