Quick question mate. from the Donnington pictures it looks like you run some kind of strip around the bottom of your front spoiler. If yours rubs the ground under hard cornering and brakeing like mine does, I’m guessing this strip is to protect the splitter a bit? Could you let me know what this protective strip is made of and how it was made and any other relevant details please. I need to make something for mine, before it wears all the way through.
Sean if you like, i have had a carbon strip that is moulded around the lip, almost exactly as high as the top secret stuff, of my new splitter for exactly that purpose. Didn’t have to be carbon but i wanted something that would look good without needing paint that would just scrape off, and use the existing undertray holes to be held in place. That way i just make one of those up every time instead of painting the splitter.
Post some pics in a day or 2 for you. Also to stop the bolts wearing away you can get some titanium items, i got from RS components, expensive so just the ones that wear away. Plus sparks out the front and flames out the back could i ask for more
I wouldn’t have said carbon is the best matrial for this, you will leave shards of sharp CF around the track just waiting to give somebody a puncture.
I have made a bit of a fix for Croft on Sunday, basically the ally floor I made sat inside the splitter, I have simply unbolted it and rebolted it to the underside, so it gets the bolts and then the ally floor before the splitter.
The bolts and ally cost me nowt, unfortunatly I can’t say the same for the bloody spolier!!
