Hi Roy
The Accusump is about $500 not sure about fitting.
The Ohlins available from Lotus is fine tuned for the Exige so get it from a dealer in the UK its �2300 fitted.
In the UK there is a performance pack that includes the 4point seat belts and the bar. This set up allows for easy fitment of a roll cage.
The sc has been offered to Exige Cup car owners for �7k
have a look at the below topic for more info on the sc and other options.
I think you should either look at getting a cup car or speak to Lotus direct their motorsport arm should be able to sort you out with a Exige with Cup spec.
Adding a cage to a standard Exige is not easy, if the car has the performance pack the costs are reduced as the diffficult part of the cage is already fitted.
I dont know the costs might be worth emailing Lotus?
Hi Roy
Surely the SC offerred on the Cup car is only available on an S2…he’s got an S1?
EDITED 'COS I DIDN’T READ THE ORIGINAL POST PROPERLY
