exige starts and dies after 3 seconds
hello everyone, i was wondering if anyone could help me out here. i recently took my exige to some small mechanic because i was having some little problem and i was far up north with no lotus dealer. he took it apart and made it work again, but now we have hit a problem. when i start the car it runs for 3 seconds and then dies off. its as if the pump is not working or something has not been plugged in that’s stopping from giving fuel to the engine. can someone give me and this fool some suggestions as to what it might be. is there a cut off switch somewhere or could the computer be preventing it form running since the battery died?
thanks for your help
Is this an S1 or an S2 Exige please, cos it will probably affect the advice you seek?
Just seen your other post - it’s an S2
From the owners manual :
“the safety inertia switch is mounted at the left hand bottom of the engine bay, on the inboard face of the rear subframe, and is accessible from between the coolant header tank and screenwash resevoir. the switch is reset by pressing the rubber diaphragm on the top of the unit”
JK
thanks ill try it out and see if it helps
worked. thanks JFK. i should have had a manual with me.
helped out alot. when u come to canada, u have a nice box or beers waiting for u.
I,m on my way lol…
I,m on my way lol…
mmmmm Molson…Hope he’s a Flames fan…20 years to the day and the cups coming home dude COME ON CALGARY!
