Series 1 Exige (non air con) � 19,500 miles
Private plate: S31XGE - Not included in price of sale, if you are interested in this plate then pls bid seperately
Currently running Yokohama AO39 tyres (standard factory spec on S1 Exige) with plenty of tread left, look new!!. Regular oil changes using Millers 10/60. Full Geometry check along with corner weights kept up to date - carried out on completion of suspension & brake work below (brakes and suspension upgraded in last 1000 miles)
New vhpd was put into my car at 14,500miles and has covered approx 5000 miles since. This was paid for under lotus warranty. Pls be advised this was not a strip down and rebuild, this is a brand new engine built from scratch by hanger 111 and scholar. Engine was dyno’d at scholar giving 230bhp & 160lbs torque. Car now producing in the region of 240bhp and 170lbs after 8 injector system installed.
Car has just had a full mot and c service � all stamps available in log book (alternator replaced in mot)
Although the car was built as a project with track work in mind, my car has only recently been finished and has never been tracked to date. Also 2500 miles of the 5k total on this engine were ‘run in miles’ I am selling due to a change in lifestyle, i.e. buying a house with the misses so am having to buy something a little cheaper and more practical for the time being.
This car would make an excellent track day weapon, only cut off switches and roll cage to be installed for full track race conversion. To build an exige of this spec would cost you minimum 35k. I have receipts for the purchase of my car and upgrades totalling approx 35k. All work can be confirmed with either Hanger 111 or Elise4Track who carried out all work.
Pls either call or text me on my mobile: 07764 499619. If I do not pick up straight away i am probably at work so pls just leave a message and I will get back to you. I am in no immediate rush to sell so no time wasters pls. I am looking for �24,950 ono, all other reasonable offers will of course be considered.
Mods to date:
Interior:
1.Luke 4 Point Race harnesses - (Hanger 111)
2.Three Piece Leather Centre console ordered from Hethel (Hanger 111)
3.Black gear gator, gear knob and satin silver handbrake grip (Hanger 111)
4.Rubber side seal stone chip protectors (Hanger 111)
5.Oil pressure/temp gages plumbed in behind centre console (Hanger 111)
6.Carbon Fibre twin skin Mulsanne C race seats (Reverie)
7.Extinguisher fixed in passenger foot well (Hanger 111/Reverie)
8.Upgraded audio speakers (Infinity)
9.Satin Silver indicator stalks (Elise Parts)
10.Carbon Fibre Binnacle Stack Surround (Elise Parts)
11.Carbon Fibre lower Centre Divider (Huskydog)
12.Carbon Fibre Steering Column Surround (Huskydog)
13. Floor corrosion protection done under lotus warranty (Wilson’s Lotus)
Exterior:
1.Carbon Fibre side pods (Reverie)
2.Carbon Fibre rear diffuser (Reverie)
3.Carbon Fibre Front Splitter (Reverie)
4.Lotus motor sport extended roof scoop (Reverie)
5.Extreme white light upgrade (Hanger 111)
Brakes:
1.Braided Brake Hoses (Hanger 111)
2.Front 4 pot callipers, rotors and bells with pads (Elise4track)
3.Rear brake kit (Elise4track)
4.Brake master cylinder bracket (Hanger 111)
Suspension:
1.One way Adjustable Nitron suspension dampers with custom springs (Elise4track)
2.Toe Link Kit (Elise4track)
3.Wishbone Bush Kit (Elise4track)
4.Adjustable track rod kit conversion (Elise4track)
5.Drop link conversion kit (Elise4track)
Engine:
1.Shortshifter (Elise Parts)
2.Gear Linkage (Elise Parts)
3.Sports exhaust - Quicksilver (Hanger 111)
4.De-Cat Pipe - (Hanger 111)
5.Magnecor Ignition Leads (Hanger 111)
6.Performance Spark Plugs (Hanger 111)
7.New engine built at Hanger 111 / Scholar under Lotus warranty at 14500 miles >>> 1.9 litre block conversion incl uprated steel con rods, Cams, forged pistons, new liners etc (Hanger 111 / Scholar)
8.Head port and polished (Hanger 111 / Scholar)
9.AP Racing clutch upgrade (Hanger 111)
10.Vernier Pulley’s incl performance cam belt (Hanger 111)
11.Baffled Sump (Hanger 111 / Scholar)
12.Larger Injectors (Cream Injectors 244cc/min @ 2.5bar - Hanger 111 / Scholar)
13.Remote Thermostat (Hanger 111)
14.Motorsport Oil Cooler system (235mm 19 row cooler - Elise4Track)
15.Pectel SQ6 ECU (with data logger) + motor sport wiring loom replacement throughout (Elise4track)
16.NTK Wideband Lambda sensor kit (Elise4track)
17.8 injector fuelling system modification, using the 4 standard injectors in usual place, Adding 4 larger direct to trumpet injectors on custom fuel rail in modified carbon air box (Elise4Track)
18.Uprated engine mounts
