Does anyone know what the inlet diameter is at the point immediately before and after the supercharger (Eaton) on a Toyota S engine?
I’m still considering my engine options. If I go for forced induction then I need to have a 34mm restrictor located within 50mm of the compressor blades.
I would have thought if you put it after the SC you would end up with so much parasitic loss from trying to force the air through it would not be worth it, you’re best bet would be just before the throttle body or just after it in the throat that leads to the inlet, everything is much bigger than 34mm though
Now I’ve found your website I can see why you’re getting all pissy about yer trademark clicky . I know you like your bling fella but you’ve gone too far.
Now I’ve found your website I can see why you’re getting all pissy about yer trademark clicky . I know you like your bling fella but you’ve gone too far. [/quote]
