Any recommendations as to where I can get the Exige tested for MOT. My delima is that motor runs rich (it needs to, as per the 190bph spec.), but it may fail the MOT because of this.
Do I need to install a CAT, just to get it through the test, then remove it afterwards?
Installing the CAT is not difficult, nor a lengthy job…
You can easily do it yourself, or of course pay someone !!
The biggest problem is that the sections of exhaust the the CAT fits between come with studs rather than bolts, so you need to be able to prise the sections apart by about 2 cms to get the thing in and out, and this may mean slackening off other bolts on adjacent sections as well…
I recommend replacing the studs with decent bolts, cos from then on it is easy to just slide the cat or replacement pipe in and out without messing with other sections at all…
