Exige Mk1 Aftermarket Wheels
Does anyone know why Rota do not make the Slipstream alloy for the Exige, the ones they supply for the Elise look very good for the price.
What are the offsets I need to look for front/back.
Can anyone recommend a decent aftermarket alternative to the standard Rimstocks which I understand are heavy.
Anyone got a set of wheels for sale Cheers Tony
Tony, quite a few manufactures have mades Elise wheels and not Exige ones, can only think that it’s a demand issue.
Anyway the sizes are:
Front
PCD - 95.25
Holes 4
Diameter 16"
Width 7J
Off-set +7
Rear
PCD - 95.25
Holes 4
Diameter 17"
Width 8.5J
Off-set +5
Steven H
Thanks Mate, I am going to contact Rota and see if they can do wheels to fit, or if not see if they will supply wheels in corect size but without stud holes drilled.
What are your thoughts about hubcentric hub adaptors to change pcd to 100mm?
Cheers Tony
I think hubcentric hub adaptors are an acceptable way of expanding the possible choices of wheels you have, but I’d prefer to have hubs made with the new pcd already on them and there is at least one company that do these.
It would certainly be a more expensive way to achieve the desired result but I just don’t like adding more parts in a fix to any solution
