Exige Cup 260 full specs.
Here are the specs of the new 260. Hope apreciated.
Translated from italian:
First of all the car can be bought fully homologated for for street use.
Ita has a 6 point cage and 4 points seatbelts included in price but sold separately in order to mount them only in track use.
Engine:
2008 engine with chargercooler of bigger size, bigger air scoop and new sistem of injection of the ECU T4 max torque of 236Nm at 6000 rpm.
0-100km/h 4.1 secs circa. Max speed 250km/h
Suspensions and wheels:
Ohlins adjustable dampers and roll-bar. 16 rays wheels in hi power silver
Security and anti"fire":
Cockpit mounted fire extinguisher and in engine usable from inside and outside the car.
Also has electric isolation in and outside car.
Accusump system:
Has an extra oil tank with compressor that keeps pressure constant.
Clutch and differential:
ultralight clutch and Torsen “anti block” differential.
Anti skating LSD that permits manuale regulation from 7%
VLC and Launch Control
Brakes:
AP racing and self-ventilated and bore discs of 308mm and hi res. PAGIT RS14 pads on 4 piston clamps.
Interior & Exterior:
Steel T45 roll bar
No airbags and centralized closure.
2 probax seats leather and microfiber
Alcantara dashboard and electric windows
Price:
� 56’034,00 = � 42’158,74
P.s. How do you upload pictures and hoe can i put the avatar on my profile?
Look here web page
By charge cooler i’m guessing you mean inter cooler ?? or does it infact use a liquid to air charge cooler ??
� 42’158,74
mm
its 56k
�42k or �56k I believe
Base price is �42K (ie euro56K) PLUS Local Taxes (ie Vat) & on the road charges. That brings it near as dam it �50K, then you can add “extras”:
Options (all subject to local taxation rates)
� FIA approved 70 litre fuel cell (track use only)
� Lotus Sport limited slip differential (plate type)
� Air conditioning
� Metallic paint
� Lifestyle paint
� Race battery and holder
Other more hardcore track options are available � prices on application (ie �Level Two� exhaust with de-cat pipe, dog gearbox, Recaro/Lotus Sport driver�s seat with 6-point harness etc).
So you’re probably looking at �53k to �55K in reality
