exige C-ONE N/A
Hello every body
my car
Uploaded with ImageShack.us
exige 2006 sport pack
moroso oil,lotus motorsport ecu,motorsportclutch with lsd,cup airbox,mano SPA p/t oil,stage2 exhaust
lightweight batterie,gearboxclose ratio KAAZ(c-on)
nitron
alloy radiator
light carbon/kevlar hardtop(2.4kg,standart 10.5kg)
light carbon engine cover CUP half of standart
light bigger spoiler LEA carbon
light LEA carbon front panel
light LEA carbon scoop bigger
light wheels cup 1.4g
light brackes ultradics sector111 front and rear
to be continued…
Looking good - but your steering wheel’s on the wrong side :smiley: :wink:
OO I like you, nice mods and nice car :sunglasses:
Looks like nice man cave too!
Very nice… Lots of light things…:slight_smile:
mano SPA installed in an aeration
HI ,
New splitter in carbon with licence plate deleted :stuck_out_tongue:
I continue has to gain weight until the engine tires and to replace it by one 2.0L
save 4.3 KG by seat
my roof output Carbon
input Kevlar…only 2.5KG
Good stuff.
2.0L engine, a stroker kit for the 2zz? If so what power are you looking for, have you read up on any conversations?
http://www.lir-racing.com/catalog/product_info.php?cPath=744&products_id=738&language=en
or stroker to monkey…
Good stuff, very interested to see how it works out, keep us informed :thumbup:
I stayed 1.8L but did the following:
Toyota bearing
Fidanza flywheel
Fidanza clutch
Eibach springs
Piper stage 3 cams
Baffled G-pan 3
Polished & Ported head skimmed again (compression now 12.5)
MWR Supertech valves
MWR Ti retainers
MWR Underdrive alternator pully
MWR water pump pully
Track Group uprated oil pump gears
MWR TRD 170f thermostat
Mahle piston set 12.3:1 compression 82mm Xylan Coated
Track Group billet rods
OEM Crank
NGK race plugs
Block Nikasil coated
2bular Big bore (port matched) 421 manifold/decat/repackable GT3 exhaust
440 injectors
Updated fuel pump
DD Performance Research intake manifold and short ram intake.
DD Performance Reseach 80mm throttle body assembly
Radium fuel rail
Radium catch cans
Eliseparts ECU
231bhp/8500rpm
202Nm(20.60kgf*m)/7500rpm
